- Dec 27, 2014
- All over the place
Hi again!
Some more questions. And thanks again for your help!
So I'm going to be buying a PrimoChill CTR Phase II Reservoir. In the picture of the supplied accessories, there are 4 normal port plugs and 2 other (currently unidentified) port plugs. Are those unidentified ones for fitting LEDs?? If so, can I put an LED in the bottom and the top of the res? And would those plugs be waterproof to put an LED inside or would I need to buy something else?
Re filling the loop. Do I have to fill via the res or could I fit a fill port to the top radiator and fill the system from there? The rad is the highest component within the loop. With gravity and all, I was thinking it would speed up filling the system as I wouldn't have to top up so many times. Would it make any extra bubbles or cause bleeding issues or any other problems?
And finally, if I got the 360mm tube reservoir instead of the 240mm. Would having a greater volume of water in the loop reduce temps at all or is there no thermal benefit whatsoever?
Thanks folks!
Thanks folks!
