- Aug 2, 2014
Hello! I recently upgraded from my crappy X4 640/Gt220 to this rig i have in sig.
I was googling a lot when i was waiting for components so i can easily jump into overclocking and squez it up to 4.2Ghz+ with no problem when i have relative good psu, cooler and mid range mobo when a lot of peoples was ocing on this stuff too. So i was watching youtube, google reading threads about OCing, and no one had problems with OC.
Mine problem is:
I OCed to 3.6Ghz (from 3.5) i saved and left bios, pc shut down, then it was trying to start for 2times, and then it was working, pc was running withou problem. I started some stress testing in prime95 and i was looking for temps in speedfan and clock speed in cpuz. Everything was fine! I had temperatures after 15min test around 45-50°C i think it was really great imo. So i boosted it to 3.7Ghz no volt adds, no other stuff wasnt changed. Pc again started to starting for 2times then it was ok. After loading prime95 (just starting program) pc crashed (lag) so i hard reset it and let it start. BSOD appeared so i went down to 3.6Ghz and it was fine in win, but my pc cannot start at one try. (I hope you understand my english isnt 10/10).
I have no idea what to do now. I want to overclock it as much i can go. I can run cpu at low temps with huge cooler i have, but some "soft" failures wont let me overclock... Im running at stock now, here are screenshots from bios (its updated 2014 version)
Can anyone help me what to do now? Im using W7 HP 64Bit.
Mine problem is:
