Hi guys
I recently purchased a new cpu, and to go with the new cpu I also bought an after-market cooler.
I made sure before buying that the cooler would fit on my board, I called a few different reputable pc shops and talked to some techs about it, and I also referred to this website: http://pcpartpicker.com/parts/cpu-cooler/?compatible_with=biostar-motherboard-ta790gxb3
My problem is that I can't align the block of the heatsink to my cpu properly:
http://files.laggaming.com/members/Se7eN/cpu.bmp
I've tried to put the screws in every possible combination of locations (2 possible locations per screw, 4x screws), and for them to align with the motherboard, this is the only way I've managed to get the cooler on. The heatsink doesn't seem to come flush with the chip if I rotate it either.
The temps have gone down drastically, I haven't hit above 36C while gaming, when normally I would hit 58C, but I'm still worried that that part of the chip may not be getting proper cooling, and that it could eventually damage the chip.
My intuition tells me it's something silly that I'm not seeing at the moment, and I would greatly appreciate some help.
Thanks!
MotherBoard: Gigabyte TA790GXB3
CPU: AMD Phenom II X4 965 @ 3400MHz
Cooler: CoolerMaster Hyper 212 EVO
Max temp for this chip according to AMD: 62C
http://products.amd.com/en-gb/DesktopCPUDetail.aspx?id=617
Thanks!
