Hello Overclockers,
I am quite a noob at overclocking and i need some help from you experts please. I currently have the following:
Asus Z97-A
Intel I-5 4690K
G.SKILL Ripjaws X 16GB(2x8GB) desktop memory
2xSamsung 840 EVO 250GB in Raid 0
Gigabyte GTX760 GDDR5 OC Graphics Card
EVGA Supernove 850W B2 PS
Enermax LIQTECH 240 CPU Liquid cooler
Arctic Accelero Hybrid II 120 Water Cooler for my graphics card
I plan on adding another Gigabyte GTX760 with Arctic Accelero water cooler
I want to get any kind of an overclock but im having a problem. if i use the EZ Wizard in the bios to overclock, its works great without my GTX760 graphics card with the attached water cooler(which does have a pump). The onboard graphics works with the automatic overclocking. Adding in a basic HD5450 graphic card in the PCIe slot(no extra power connectors needed) works also with the overclock. As soon as i connect the GTX760 graphics card with Arctic Accelero cooler and try to boot, i get no video on the screen and a series of a long beep followed by 3 short beeps which indicated a video problem if you look up the beep codes. To recover from this problem, i have to remove the GTX760, go into the bios, and reset to default settings. The GTX760 card works just fine with default(no overclocking) bios settings. As soon as i try any overclocking, i get no boot and no video and the beeps i mentioned above.
I've tried using the AI suite 5way optimization software to overclock and i get the same problem.
Could i have a power problem where i don't have enough wattage available with 850 Watt PS? Is there an issue with the graphics being overclocked when those cards are already overclocked? I'm not trying to OC the GTX760 and i've looked everywhere in the bios to find GPU overclock settings and i can't find any.
I hope you guys can help me. I've been stuck on this for a week.
Thank you in advance!
Asus Z97-A
Intel I-5 4690K
