- Sep 29, 2012
- Fresno, CA
Dimensional Overdrive
There is not much to this build log, but I think it proves that for a small investment (e.g., a few eBay purchases here and a few good discount deals there) you can revive an older (worn down and noisy) system. This is my older Dell Dimension E520 from 2006, it had a super slow Core-Duo and passively cooled 256Mb GPU. I didn't think to test it prior to the upgrades but last night it scored 2067 on a performance test. It is vastly more responsive than it was prior to, although it still does have an occasional pause when loading certain programs, it is nothing as slow as it was prior to this round of upgrades.
Its upgrades include:
1. A refurb Dell E520 MOBO (I found a bent CPU pin that I tried to move back, but have another used board on the way just to be certain it does not cause any future concerns).
2. A Quad-Core QX6800 CPU, (which required that the BIOS has been updated to the most current version 2.4.0.)
3.
4. PNY 650GTX 2GB. (Found this for half price at Bestbuy online.)
5. Kentek 600w Dual Fan PSU. (Scored this for under $35.)
6. A new 120mm CPU fan and Silverstone filter (for BTX FF MOBO), two 80mm and one 92mm Noctua Redux (gray colored) PWM fans (will attempt to use the two 80mm on the rear vents to make case positive pressure and the 92mm to either blow on the GPU or as pull fan at the rear of the CPU tunnel). The three Noctua fans will be connected to a bay fan controller.
7. PNY Pro 240Gb SSD (Windows 7 Ultimate.)
8. WD RE 2Tb HDD (Windows XP Pro.)
9. All cables upgraded to a themed sleeve and SATAIII (even though this system is not SATAIII capable, figured it could not hurt any.)
10. I moved a LG 14x 3D Bluray, WD Green 2Tb HDD, Silverstone USB 3.0 card (providing two rear USB 3.0 ports) from my other PC to this one (I will be upgrading that system with a LG 16x (same model) and a new edition of the Silverstone USB 3.0 card.)
(Also to note this was prior equipped with a U.S. Robotics 10/100/1000 NIC and a Soundblaster X-Fi card)
I had originally attempted to move my Windows XP over to the SSD from an HDD, but failed every attempt, ultimately wasting my entire weekend, to which I then decided to enact plan-B (which is vastly better I think and am not certain why I did not go that round to begin with), entailing a dual OS using a boot program (EasyBCD). So now not only is this an entirely revamped system, it is two systems in one, providing the benefits of both 64-bit and 32-bit Windows. Joy!
Now onto finalizing my Liberty Raven build—once and for all.
(Sorry for the blurriness in several of the images, it appears my Canon digital camera is starting to fail.)
