Just picked up the AC version and after initial install of audio drivers without the realtek program I came across a decibel feature under the sound options. I didn't bother messing with it and only remember looking at it briefly. I am no longer able to find it. I looked in the realtek program to see if volume can be increased but I can't find anywhere where there decibel amplification feature is at. I was on a xonar ds before that had a lower max decibel level than the onboard audio on this motherboard. I can tell by quite a bit while using my ath-m50's. I know there was a drop down menu and it had a few options that said +xxdb. Also I would assume there would be a feature for that as well seeing as the motherboard has a built in headphone amp. Anyone that has this mobo know what I am talking about?
Btw keep in mind the volume is not being reduced in any way. No changes aside from driver installs have been made.
