- May 15, 2010
- Euroland, Denmark
Hey guys,
I have an issue with my newly built loop. I put it together about 2months ago, and since then, i have changed the water about 5 to 7 times at the very least (GPU RMA Issues)
So, when the loop was made, both the rads were cleaned, using boiling water, i did this method about 5 to 8 times per rad, and the liquid was clean when it came out the last 2 or 3 runs.
The tubes where new EK 10/12 solid acrylic tubes, cleaned inside as much as possible, just not with boiling water, but with a cleaning solution, they were sparkling when done.
Currently the loop is ripped apart, the CPU block is partly blocked off, and some of the plexi tubes have a strange gel like coating around the fittings, aswell as some of the tubes have a thick gel like film on the inside.
I am now cleaning the loop ONCE more, when its all clean, it will run Meyhems loop cleaning kit for 24 to 48hours (cant rememeber the time) I ahve run destilled water with 2x kill coils.
I plan to keep going this way, but also add some addictive this time to deal with ph levels.
Can anyone shine some light on what the hack could be growing inside my loop? Its driving my nuts!
