Both the number of sticks, capacity, and speed can play a role for that voltage.
Its been so long since I have been on that platform... QPI/Vtt looks in order to me, but every system is different. If those values are the least amount you need to be stable for your uses, then you are good.
That said, is there a reason you are running dual channel on a triple channel platform?
The QPI voltage is affected by anything attached via RAM or PCIe slots.
As long as you keep temps in check, 1.4V is safe.
Just use whatever is necessary for stability under 1.4V and you'll be fine.
Some are saying 1.35v to 1.40v is about as high as you want to go with QPI/VTT setting on the 920, but from what i have been reading there is always a difference of opinions to this. You can lower it down and raise the CPU Voltage instead to compensate.
1, http://hardforum.com/showthread.php?t=1410119
Some basic info ref your overclock here above.
2, https://www.google.co.uk/search?q=i...-8#q=i7+920+qpi/vtt+voltage+settings?&spell=1
This is a complete page of info to read through about Overclocking the 920, and the QPI/VTT Settings people are using achive a OC of 4.0Mhz.
Best of Luck,
Ajay.
How do you have a total of 8GB in triple channel? Math is escaping me this morning. You also said 2x4GB which tells me two sticks. You should be using 3 sticks and with a density of 2GB that would be 6GB.it was originally 2 6gb kits but 1 dimm died and when i dropped back to 10gb it was forced into dual channel and was too unstable, so i dropped back to 8gb and triple channel is enabled again
M erged your double posts.
Honestly, you'd be better off putting the money into newer equipment than into a custom loop right now.
Agreed... while what you have is serviceable. Sell what you have, don't buy custom and get a new PC and use the AIO you have.
Oops, you did say 4x2GB, LOL! That last stick, I believe is dual or single channel (depends on motherboard). If you are not using more than 6GB, just run 3 sticks is my take.
As far as upgrading, you don't need S2011-3... you can go Haswell/Z97 instead. That said, if you are stuck on 2011-3 grab a 5820K and save $200 on the CPU. The boards are a little more expensive (say $40 more than the Z97 extreme 6 we typically reccom). You will get killed in the quad channel DDR4 memory though. But if its still working for you, there isnt an immediate need. You can take most/all of the custom loop forward anyway...
You still got plenty of wiggle room on the Vcore if you wanted to go for 4.0 and i see what you mean about the Temps, so if you have already order your loop it would help.
And then if you do decide to up grade later its just a motherboard and CPU + RAM swap out, also while your waiting to make any decision the prices will always come down sooner or later.
Ajay.
If I remember it good then I needed about 1.35V QPI/VTT for 3x2GB@1600 memory and 200bclk+. 1.55V QPI/VTT for 200+ bclk and 2000 memory.
QPI/VTT has to be higher on ASUS boards but in general it depends from memory clock, memory capacity and bclk clock. Also CPU with good memory controller needs lower voltage.
What are your Uncore and QPI speeds set to?
