As the title states I'll need to replace my Swiftech MCP35x here shortly as it's not turning on consistently. I'm going to try and take it apart and clean it out and see if that helps but I'm not hopeful. I also have the MCP35x Reservoir v2 for this pump (see sig).
So my question is, should I just by another 35x or is there a newer/better option out there? Would I need to replace the reservoir also or can it mount on top of other Swiftech pumps?
