Hey guys, in december of 2013, i was building my very first watercooling build. Since that time i was searching for tweaks and improvements on the esthetic side.
Today my build looks like this :
I am going to :
- remove the ****ty stickers over the PSU (was i drunk or what ?),
- change de tubing for 13/19 crystal clear (primo chill ones, masterklear is so crap, i used them and i am very disapointed),
- change the water for red pastel with blood red dye,
- remove the 120/120 rad for more clearance,
- put only straight chrome fitting (black painted ones looks so cheap and crappy),
- change the motherboard and CPU (red themed MOBO with engular HDD connectors),
- put some cable management little plastic things for the VGA and MOBO red sleeved cables (they look messy),
- change the fans for quieted corsair SP,
- put more leds, RGB ones with remote control to be able to shut them down.
I was wondering to remove completely the HDD cages to put a 5 way hot swap thing on the optical drive bays. But it won't fit on the top (i think) and i dont know if it will looks good on the bottom with the rad above it. I woud be able to hide the pump and the sandwitch.
What do you guys think about that ?
I am going to :
