- Jun 30, 2004
- San Antonio, Texas
looking to go MATX for space saving reasons. While I have been looking I thought maybe you lot could help me with your experiences. And yes it has to be MAXT not ITX as I still want to sli some Strix 980's under water of course.
What I'm looking for is no wider than 12 inches or 305mm. Would dearly love it to support dual 45mm or 60mm thick 120mm or 140mm rads (240mm 280mm) a 360mm would be a huge plus for one of those two rads. Can be push, pull or push/pull. Length and height not 100% a concern as I can make the room on the shelf it needs to sit on just cant make it any wider lol. Not overly concerned about optical support as I have an external drive for those rare occasion I use one.
parts to be cooled will be the sli's Strix 980's and a 4790K so I'm pretty sure I can get those comfortable with dual 120's/140's
Thanks for the help
oh and almost as important as the width it needs to be light weight as well.
Thanks for the help
