So i just finished putting my computer together lat night. The issue is between the asus z97 sabertooth mark 2 board and the Thermatake v71 case. I had the front fans and top fans hooked up to molex then to the ChA fan 1 header just like it said. I turned it on and no fans worked but every other component worked perfectly. I then powered it all of and decided to reset the connections. This time the fans turned on,, then with a loud pop and some smoke the capacitor blew on the v71s power board on the top. Why there would be a power surge i have no idea, it was all hooked up to the surge protector and nothing else went on. Needles to say i unhooked the power board completely and plugged the fans directly into the other 4 fan headers bypassing the now broke power board and every single fan worked as it should perfectly. My question is, whats at fault, the fan header 1 or the board on the case? Ive never seen this before. Should i try and get a new board for the case and just keep skipping the fan header 1? or get a new mobo/power board. Newegg offered a full RMA on both the mobo, and case which is a hassle but an option. Thermaltake has been awesome and is sending me new control board which is awesome, and im waiting on the new board to swap to decide if the RMA is even worth it. Basically if it all works correctly i wont even bother swapping just because one fan header is out. MY question is am i wiring it properly?
The build:
-i7 4790k
-asus z97 sabertooth mark 2
-asus gtx 970 4gb
-ripjaw 16gb 1866 ram
-evga 750 gold power supply
-h105 liquid cooling
-v71 thermatake case
-250gb ssd
-1tb hdd
-other bits/
The build:
-i7 4790k
-asus gtx 970 4gb
-250gb ssd
-1tb hdd
-other bits/
