I'm looking for a software that will allow me to make a graph of the frame rate in games. For example writes the value for the current fps to an excel sheet, so that they can be used to create a graph.
Rivatuner should do the trick. As far as how you actually do so with the software, I don't really know as I've never used it for that purpose. I've only used it to display a windows with some stats, but I know it does allow logging of said stats.
Fraps does indeed have a logging function, but it gives you the min, avg and max values only, and not a data point for each second. Still, its very useful.
From doing some reading it looks like FRAPS should also have a full log function (benchmarking setting) but I am unsure if it will do a full framerate log with the trial/free version. May be worth looking into a bit more.
Looking at that you need to check the FPS box and not just minmaxavg.
