It's not likely that the layout of your Giga is the same as the Asus. Asus typically does their own thing when it comes to the "specialty" cards like this. You may be able to use the double pump but the HS and cover may not work. You'll need to compare your card to the ASUS in detail. Here's some shots of the ARES uncovered. http://www.techpowerup.com/reviews/ASUS/ARES_II/4.html
