OK quality, but loud bluetooth speakers?
torin3
I recently got this portable bluetooth speaker http://www.newegg.com/Product/Product.aspx?Item=N82E16855546001
Not a bad little unit, but I work around 30 CNC mills and lathes. While wearing hearing protection, I can barely hear this at all when I'm right next to it at max volume.
Does anyone have a suggestion for one that has quite a bit more volume available that is around $30-40? I'm ok if battery life sucks, as I should have access to power most places I'm planning on using it.
Thanks!
Do I understand that you work in an environment that is so loud that you have to wear hearing protection, but you want to make it louder still?:shock:
No, not louder, just change the quality of the sound from random noise to music or podcasts.
I wouldn't buy a solitary speaker myself but personally would suggest the goalzero rock out 2. The non bluetooth version is $60 and this one is $130. Apologies if price is too high but you might want to look into ones that aren't bt to save money.
www.goalzero.com/mobile/p/210/rock-out-2-solar-rechargeable-speaker/
Unfortunately, that is a bit rich for something that someone might walk off with. (This is where someone threw away half of my wired speakers a month ago)
I'm thinking possibly this:
http://www.newegg.com/Product/Product.aspx?Item=0ZK-0203-00005
Looks like it might have physically large enough speakers cones to be loud enough.
Can't wear wireless noise cancelling headphones?
Nope...
[sarcasm]That wouldn't be safe...you couldn't hear the fire alarm if it went off...[/sarcasm]
I wear them when I work on the weekend. (Soft foam earplugs /w headphones, though not noise cancelling.)
The weekend supervisors don't have a problem with it.
Other than appearances, I don't see a difference between what I do on the weekends, and what goes on during the work-week. They can have radios blaring and wear hearing protection, but not supra-aural headphones and hearing protection.
I've considering getting circumaural hearing protection with built-in bluetooth, but I'm afraid after spending $100+ on it, they would tell me no anyway.
