- Jan 7, 2006
I'm looking at these things and they seam to be priced similarly to full sized versions of the card, as well they sport the same ports and clock speeds. What am I missing here, is their any reason not to buy a mini version?
On the contrary. You can overclock on air on the smaller ones too... . I just mentioned above in fact...Definitely not a something to run above stock unless there's some clever water cooling.
I'd suspect lower overclocking headroom because of a likely smaller cooler.
I was referring to a hypothetical low profile bracket card, not this 970. I would think some overclocking would be possible on air. But I have an ITx case with very little space so it wouldn't fit. I use a midatx for larger GPUs. http://www.overclockers.com/forums/attachment.php?attachmentid=160392&d=1424809108 if it were narrower and longer it would be ideal for desktops, but the demand is so low and and the shape is a little irregular unless you remember the riser days that there's little need to manufacture one.
Why did Galax send a confirmation email thanking me for my purchase? Order #328.
I logged into PP to see the conversion but 100% did not pull the trigger. I checked in PP and no activity is showing so it looks fine. Still that email though ...
I want one for my sff build but the heat is what scares me. I have to worry about temps in a small build
