Well, you've already replaced the motherboard once. The chances that it's the CPU are almost zero.
Have you tried disconnecting all storage devices and only using CPU/mobo/RAM/GPU to see if you get a different post screen?
Edit: Just to be thorough, since you have a board that's two generations old you probably have an old CPU, correct? Have you tried it in the UD3?
I made that statement in post #3 about n0t knowing what was in use, because in "my" mind I was betting myself that you had Kingston ram. AND guess what, I find that you do in fact have Kingston ram. You are probably shooting your ownself in the foot by not using the ram voltage that is called for and in this case that is 1.65V or so you said. There is certainly no assurance you can arbitrarily lower the voltage to only 1.5V even if you underclock the ram.Kingston Hyperx blu 8GB(4x2GB) @1600Mhz (could it be that ram are rated 1.65v and MB supports 1.5V?I was running them at 1.5V @ 1333Mhz),
bios telling me that some configuration was not right
Got a sabertooth 990fx R2.0 and everything is ok now.Should have taken it in first place.Guys thanks for your contribution.
