On my current case and my hopefully new case (corsair 200r and cooler master storm scout 2) there is room to top-mount two 120mm fans or one 240mm radiator but not both, due to interfering with ram, or other motherboard heatsinks or such
. My question is, would I suffer in terms of cooling performance on my h100i by mounting 3x80mm fans? I have it ghetto mounted right now with two 120mm fans and my i7 3770k OC'd to 4ghz at stock voltage and my temps are 28C idle and 60C at full load. If I clock it to 3.7ghz will the smaller fan config on the radiator, will my temps be considerably higher?
