hello
having used the Aquaero 6 for a while and without issues,I decided to slave a Aquaero 5 to it.
Everything works great except the fans that have a splitter cable that each connects 2 fans to a fan header for a total of 3 splitters
the issue Im having is on the slaved A5 where splitters are used,the fan rpm fluncuates constantly.
im positive the curve settings are correct as the Aquaero 6 fans work properly
the a6 where no splitters are used work well
the pwm header on the a5 has the tach wire removed
ive tried every varable in the controller setting without any difference.
does anyone have any idea on the cause of this?
thx...
thx...
