- May 20, 2014
- Chaparral, NM
- Thread Starter
- #21
I have always wondered which temp was each. Now I know.OK see that CPU temp at 56 and the package temp at 36. That's the issue. You want them 10c apart from each other or less is even better. The CPU is the socket temperature and once it starts to get hot like that you have to work at cooling it down. The package is essentially the core temperatur and is nice an cool because of the AIO. But the socket( CPU) is the issue when you try to go faster I can see it getting into the "danger" zone and the board reacts by throttling or shutting down. In this case it's locking up. So get those fans in there as suggested and that will help a lot. Also make sure that the ram has the approprite voltage of 1.65 and the timings should be 9-9-9-27-36 according to the SPD tab.
Okay it would be nice to get to 5.0 if its not possible fine but I'm trying to reach atleast 4.6 to 4.7 4.5 the lowest if I can.I looked for my other threads and couldn't find them. As far as the sabertooth990fx it was just a high price. For my cooling I have the H100i which I would say is better then the 212 evo that I had and the case that I have now has way better airflow then my last. I've got from Tomshardware that some one has reached 5.0 on the same exact board+cpu. Sorry if I asked this question before but no need to be rude you could of just passed this thread up if you didn't want to help me.
Now for RGone if I can get some type of video of some sort or thread that could help me on reaching at least 4.5GHz that would be great. I don't think games run or need 4.5GHz to run at this point but ill try to reach it if I can.
Forgive the hack n slash mounting. I'm cheap and didn't want to spend money for a block mount so I made one. But I used threaded rod to the backplate. Which left lots of extra poking out so I mounted some old cpu fans to it. Don't know what the temps are but with that kind of air it can't be high. Also I moved the right fan to the opposite corner so its blowing between the ram and southbridge. Note. The sticker off my VRM block that says "dual intelligent processors" is blowing off. Its flapping all around. Guess Asus didn't plan on constant airView attachment 161748
Though I will say blow the dust off that darn speaker please
