Sup Guys! This is my first build, ive had it over a month now,. at first i was just using Pure distilled water with One Silver coil..i ended getting some residue on the Reservoir, not sure what it was but it seemed to be Algae to me. i dumped it all. and gave it a cleanse with soap and vinegar. I bought The Nuke biocide stuff and some coolant. the mixture is pretty much id say 90% distilled water and the rest is the thermaltake coolant with a few drops of the Biocide and now TWO silver coils. its been maybe two weeks and the tubes are all getting cloudy, even around the silver coils. I cant tell if its some kind of algae or just maybe dematerialized coolant? i have even heard it can be the Biocide or tubing causing this? any recommendations to fix this?
All Materials are the Stock XSPC kit parts.
XSPC RayStorm D5 Photon AX360 WaterCooling Kit
CPU Waterblock
XSPC Raystorm - Intel/AMD
CPU Block LED Color
White
Reservoir Type
Photon 270mm Tube
Pump Version
XSPC D5 Vario Pump
Fitting Size
7/16" x 5/8"
Compression Fitting Color
Black Chrome Finish
XSPC 120mm Radiator Fans
XSPC 120mm 1200RPM Fan
Reservoir LED Color
White / UV
Tubing
2M (6.5')' Water Tubing - Clear (for 7/16-5/8 fittings ...
Tubing
2M (6.5')' Water Tubing - Clear (for 7/16-5/8 fittings ONLY)
XSPC-KIT-AX360-D5-PHOTON-XSPC-RAYSTORM-INTEL \
Mayhems Silver Coil 99.999 Pure Fine Silver X2
PT NUKE Biocide 0.57 ppm copper sulfate 4.1
ThermalTake Bigwater Coolant 1000 UV[/COLOR]
CPU Waterblock
CPU Block LED Color
White
Reservoir Type
Photon 270mm Tube
Pump Version
XSPC D5 Vario Pump
Fitting Size
7/16" x 5/8"
Black Chrome Finish
Reservoir LED Color
White / UV
Tubing
Tubing
