Hey guys, flashed my bios and it got really stable, so I decided to try overclocking again.
Running stock at 980mhz, my uningine valley score was 3645. Ran it in increments of 25 mhz, and saw gains until 1100 mhz. From there, from 1100 to 1200, there was NO improvement at all. Literally the scores were within 10 points of each other no matter what I did.
I know gains are diminishing with overclocking, however, I feel there should have been SOME gains.
Using XFX double dissipation r9 290 with accelero cooler, msi afterburner, running valley benchmark. Temps were under 70c for every test.
Stock run ->
Min -> 21.8
Max -> 138.0
FPS -> 87.1
3645 points
1000 mhz ->
Min -> 28.6
Max -> 138.0
FPS -> 87.8
3674 points
1030 ->
Min -> 27,5
Max -> 138.2
FPS -> 87.7
3668 points
1050 ->
Min -> 27.6
Max -> 140.1
FPS -> 87.9
3678 points
1050 with higher power limit ->
Min -> 27.4
Max -> 138.3
FPS -> 88.3
3695 points
1075 ->
Min -> 28.5
Max -> 140.7
FPS -> 88.7
3714 points
1100 -> same as 1075 about, 3712 points
1150 ->
Min -> 27.2
Max -> 140.7
FPS -> 88.4
3699 points
best run was ->
1100/1300
Min -> 29.6
Max -> 140.8
FPS -> 89.3
3746 points
Im currently oc'd to 5.0ghz, I wasnt thinking there would be any cpu limitation on valley either. Any thoughts?
Stock run ->
Min -> 21.8
Max -> 138.0
FPS -> 87.1
3645 points
1000 mhz ->
Min -> 28.6
Max -> 138.0
FPS -> 87.8
3674 points
1030 ->
Min -> 27,5
Max -> 138.2
FPS -> 87.7
3668 points
1050 ->
Min -> 27.6
Max -> 140.1
FPS -> 87.9
3678 points
Min -> 27.4
Max -> 138.3
FPS -> 88.3
3695 points
1075 ->
Min -> 28.5
Max -> 140.7
FPS -> 88.7
3714 points
1150 ->
Min -> 27.2
Max -> 140.7
FPS -> 88.4
3699 points
best run was ->
1100/1300
Min -> 29.6
Max -> 140.8
FPS -> 89.3
3746 points
