So, I get my CPU tomorrow and will be installing the fist half of things. Before I toss my water block on, I am curious re how to best apply this product. I have always used AS5 in the past and I usually spread it thin. But, it seems like the spread method has issues and the pea / rice grain size in the middle of the cpu method is just as / nearly / better than the spread method.
Further, a lot of posts I read suggest this TIM is thick and they heat it first. So, I am curious how I should go about things / seeking advice.
Also, what about the GPU? My EK block will arrive Wed. and I have never done a GPU. Here I wonder if spread / figure X / or some other method is best.
Thank you!
Thank you!
