Dirty power here, I can hear it. Any one have any cost effective, high quality power conditioners they can recommend first hand?
Do you mean air conditioning?, sorry i don't understand your question.
Would you count a BBU with voltage regulation for your use?
I ask because I have one of these, it works great.
http://www.newegg.com/Product/Product.aspx?Item=N82E16842102133
It has EMI and RFI filters and also does AVR.
Any good PSU will already have it built in. It sounds like the real problem is that your audio stuff has a poorly designed PSU (very common, as it's one of the first things they skimp on) and a real fix is near impossible without modifying the equipment.
How old is it? Could be bad caps.Im running an onkyo receiver, entirely feasible the noise may be coming from that.
Two of the channels not working could be bad caps or a bad connection. It's probably not a bad MOSFET since those generally fail shorted and cause the whole unit to not work.
If you decide to replace the whole thing, look to upgrade to HVIC or surface mount MOSFET. It's a superior technology to IPMs and through hole MOSFETs.
Well what really caused me to notice is it, I was soldering a guitar, and I noticed whenever I made ground with the soldering iron, the audio would "buzz" a bit.
