B bob4933 Member Joined Jan 3, 2014 May 8, 2015 #1 Anyone know of a way to make Vsync settings different from the prototypical 60hz or is this just whats designed into games? My main monitor runs at 75hz, so I would like to set it up to run like that if possible.
Janus67 Benching Team Leader Joined May 29, 2005 May 8, 2015 #2 Try setting vsync in your driver settings instead of in-game and see if it does the trick?
ATMINSIDE Sim Racing Aficionado Co-Owner Joined Jun 28, 2012 May 8, 2015 #3 Janus67 said: Try setting vsync in your driver settings instead of in-game and see if it does the trick? Click to expand... This. Enable in the driver and disable in-game. If you have the monitor OC'd through the driver it should match.
OP B bob4933 Member Joined Jan 3, 2014 May 8, 2015 Thread Starter #4 Whenever I try to set it to 75, it drops the resolution. The monitor reports "1920x1080" and "75hz". Ill try an "overclock" and see if that sets it.
EarthDog Gulper Nozzle Co-Owner Joined Dec 15, 2008 Location Buckeyes! May 8, 2015 #5 What monitor and what is it's native res?
