I have a Samsung UD590 UHD monitor. The native resolution is 3840 X 2160 at 60 Hz. I typically game at 2560 X 1440, and just discovered that I can create that resolution at 85 Hz in the Nvidia Control Panel. If I switch my desktop to that resolution, games like Crysis 3 will then run at 2560 X 1440 at 85 Hz.
I'm getting no glitches or artifacts at 2560 X 1440 at 85 Hz. Considering the fact that I'm running the monitor at a lower resolution than its native resolution, do you think the higher refresh rate might damage the monitor over time?
