Ultrabrite
- May 17, 2015
I've finally decided to hop from air cooling to water cooling and i have done a LOT of research on how it all works, how it's installed and what parts i need. But i'm still not completely sure whether or not my parts are compatible, or any good at all. So i thought it would be good to ask people who know what they're doing before i spend 300€ on a custom loop.
My current computer specs are:
CPU: Intel i5-4670K 3.4GHz Quad-Core
Motherboard: ASRock Z87 Extreme3 ATX LGA1150
GPU: Radeon R9 280X 3GB
Case: Corsair Graphite 760T
PSU: 550W 80+ Gold
Memory: Corsair vengeance 8GB DDR3
The parts that i have been thinking of buying for the loop:
CPU Block: Alphacool NexXxoS XP³ Light
Pump: EK - DCP 4.0 PWM (12V DC Pump)
Radiator: Alphacool NexXxoS ST30 Full Copper 360mm
Reservoir: Alphacool Cape Corp Coolplex Pro 25 LT
Fans: 3X Noctua 120 x 120 x 25 NF-F12 PWM
Tubing: 3 meters of PrimoChill PrimoFlex Advanced LRT - 16/10mm - Bloodshed Red
Liquid: Alphacool Ultra Pure Water - 1L
Fittings: For fittings i'll be using various 16/10mm G1/4 nickel compression fittings with one 90 degree fitting and a bleed port.
So, as you might have noticed i'm going for a black and red color scheme (i know my PC parts don't really work with the scheme, but i'll be painting/switching them), so if you have anything in mind that should be switched from here do let me know. But i ask for you to keep in mind the color scheme while choosing the parts. Though if there is a part that is just such amazing value that i should get, i can always try and hide it in the case or paint it. My budget is 300€ (+/- 50€). As i said i'm a complete noob to water cooling (and this forum) so any tips and help is appreciated. Thanks.
Edit: Thanks for all the feedback! I've changed the tubing, fans and liquid as suggested. And i also thought id buy some anticorrosion- and alga liquid, but i still have some questions. Is 3 meters of tubing and 1L of liquid not enough/overkill? Also, i found a thing called "tower stop plug" from Primochill, and i was wondering if that could fix my reservoir coloring issue. I don't exactly know how it works or where it even goes, but i thought you guys could lighten me up on that. Here's a link: http://www.frozencpu.com/products/2..._w_5mm_Red_LED_Secure_Hold_-_3.html?tl=g30c97
PSU: 550W 80+ Gold
