doppleganger99
- Jun 17, 2015
Hi,
Im planing on watercooling both my CPU & GPU as at the moment I have Corsair H80 cooler for my CPU.
CPU - Intel i7 970
Motherboard - Asus Rampage III Extreme
Graphics Card - GTX 970
Case - Corsair 600T
I know my system is outdated.. lol
I have everything planned out as to what to get and where to put them.. just need an opinion if the setup will work.
Watercooling parts:
XSPC X2O 750 Dual Bay Reservoir and Pump V4 x 1
XSPC EX240 Crossflow Radiator x 1
XSPC EX140 Radiator x 1
XSPC FLX Tubing Clear UV 3/8ID 5/8OD 2m
XSPC G1/4 Chrome 3/8in ID 5/8in OD Compression Fitting x 10
XSPC G1/4 90 Degree Rotary Fitting Black Chrome
Phobya Seal Plug G1/4
Phobya LED Flexlight High Density 30cm UV
My budget is around $400 AUD which is pretty much sums up all the above.
Just need opinions suggestions or feedback on this..
Cheers!
CPU - Intel i7 970
Case - Corsair 600T
Watercooling parts:
Cheers!
