- Jan 12, 2015
I know I'm trying to reinvent the wheel here, so any help is greatly welcomed I also do not mine " You are doing this the WRONG WAY *****HEAD"
I'm trying to stay with stuff that I can get at Homedepot or Lowes. Thanks Blay and Dolk
I'm going to use a old Cool-It Eco ALC AIO unit as the base plate. My next problem is what dia tubing to use over the CPU socket???? 1/4" - 1/2" - 3/4" - 1"
How high should the tubing be??? 8" - 10" - 12" ---- I'll be using copper as it is the easiest to get and in shorter lengths.
Should I tapper the tubing as is done on LN2 pots, this is for DICE only. How much insulation do I need around the tubing??? 1 - 2 -3 -4 layers
Thank You For Your Time
