as per title i am looking to buy me some new ram. i have an asrock p5b-de mobo with a xeon x5470 cpu right now i have 8gb of patriot ram but there seems to be some incompatibility issues with the ram i have. so im looking to either get crucial ballistix or MUSHKIN extreme.u see the thing right now with my system is that i can get 400 on the fsb but anymore than that and my system wont even boot. and even so at the 400 fsb i cant run the intel burn test for more than a few minutes without getting an error or prime without having at least one of the workers stopping. and i know it isnt a heat problem because i have an Antec 950 water cooler on my cpu. and plus after buying my ram i started to read reviews where they said there were compatibility issues with (my board) Intel's 965 chipset. also i cant even raise the fsb by 1mhz when i have the ram at its rated timings which is 800mhz 4-4-4-12 and when set to auto the mobo chooses the ram to be 667mhz and the timings are at 5-5-5-10. and i have read reviews where my particular ram will overclock to 1067mhz at the more lax timings of 5-5-5-15. so any advice would be great.
THANKS IN ADVANCE
RUBEN
THANKS IN ADVANCE
RUBEN
