Hello guys,
ive been at this a while now but im at the point where im going nuts and need help.
I will keep it simple.
1 - pc works
2 - pc of and put push pull system on seidon 120v v2 with heatsink/pump block still attatched
3 - pc power on > seidon light blinks once > pc shuts down into standby.
4 - i disconnect the cpu power cable ( 8 pins ) and leave the main cable connected
5 - i turn pc on and fans, hd and pump/wc fans start spinnin. Also the led indicating pci slot is working is on. Now however the leds tell my my cpu is defect or a problem.
6 - i feared the cpu was burned and checked it but its clean like a wistle
A couple of hour before it died every thing ran smooth and normal. temps where good
Is there a way for me to find out wich part is failing?
http://valid.canardpc.com/qera8a
Msi p35 platinum
intel e8500
some cheap ddr sticks about 7gb
msi gtx 750 gaming
psu a cheap cp 750w (combatpower)
Your input on this is appreciated
patrick
1 - pc works
Msi p35 platinum
intel e8500
msi gtx 750 gaming
patrick
