OCCT is very similar to Prime95 and IBT in how it stresses the CPU and none of them may do as good a job at giving a well-rounded stress test as does AIDA Extreme or XTU while driving up temps unnecessarily high in the process. Real world computing isn't like that. That's why a lot of folks are moving over to AIDA and XTU for stress testing.
JDM, let me suggest using the XTU stress test instead. Run it for 4-8 hr. It will utilize 97-98% of the CPU but leave you enough processor slices to be able to use the computer for other things while you are stress testing. I think you will find that if you can pass the XTU stress test for several hours then your computer will be stable for everyday use.
VRIN and Ring refer to the CPU cache. In this case, Load Line Calibration refers to a supplementation of the cache voltage, especially under load. You might try disabling it and just going with a fixed value for the cache since you have also fixed the cache ratio.
ok...Some of his things are still on Auto, ED. I'm not sure if it's accurate to say he's on "manual overclocking".
ok...
So, does cache ratio move if you are only touching cpu multi and voltage?
(Maybe we should pm, lol)
I just see these mentions but the reality is it's cpu multi, voltage and done. I've never touched cache anything to 4.8ghz...just trying to KISS for the op...
That just has not been my experience so far with Intels. Almost that way with some of them I've played with but with others getting a good, stable overclock seems to require tweaking with secondary frequencies and voltages.
DISABLE is not listed under Loadline Calibration. It's like normal, medium and up to extreme.
I, again, read from somewhere that setting it to extreme is same as disabling it. That doesn't make sense. Then extreme wouldn't be extreme. It would be the opposite of extreme unless there is a bios bug. Would this cause the CPU or whatever to shorten it's life? Every increase in voltage and frequency should technically shorten the life of a CPU. The question is, will it significantly shorten the life of a CPU. Most of us change parts fairly often in accordance with advances in technology so unless you are talking about significantly shortening the life of the CPU it is usually a moot point. So what if you shorten the life from 12 years to 8 years. Do you really think you will still have it by then?
should i disable Turbo since i'm at 4.4? Try it.
Although BIOS shows that i have OCed to 4.4, CPU-Z shows under specification, 4790K [email protected] GHZ. Is this suppose to change to 4.4 GHZ? CPU-z is showing the spec info encoded into the chip at the factory, not the actual speed. HWMonitor will show you the actual speed. Utilities will vary in how they report the speed of an overclocked CPU. Some will report both stock and the overclocked speed.
Core Voltage on CPU-Z is .632V idle.
