- Aug 17, 2002
I'm like owing to design a product for commecial applications. Does anyone know what the absolute most powerful LED green lights are? Preferably tape LEDs. I'm looking to build a LED light for underwater use that has its own power source internally. All of them currently need a cable to connect to the battery but I'd like to use a larger diameter Tube on the inside to wrap the lights around then within the tub have a lithium ion battery pack to self power. So I need super bright green LEDs but not sure where to start. I'd like to have 6000 lumens worth from a 3 foot tube.
Thanks
Thanks
