- Dec 27, 2008
Robbed the combo pump/water block from my Switftech H320. This sort of forced me to position the reservoir on the outside of the case in order to get it above the pump intake for filling purposes.
Radiator is a high find density 360x29mm unit. It replaces the H320 AIO radiator which was the identical size but lower fin density. I'm challenged for vertical clearance where the tower sits under the counter so a very thick radiator would have presented issues with regard to that. Went to a push/pull fan setup with six 120mm Switech Helix fans in order to address the high fin density of the radiator without adding much noise. Temps are a few degrees cooler than with the Switech AOI. Nothing dramatic but I wasn't expecting anything dramatic. Mostly I took on the project for the experience.
Liquid in the system is Swiftech HydrX-PM which has anti=bacterial and anti-corrosive agents in the mix. Must have a green die of some kind, however, so I'm not sure it's a smart choice from that standpoint.
No leaks!
No leaks!
