Hi guys, this is my first post so i apologize if i'm asking lazy/retarded questions. I did some searching but couldn't find any definitive answers on the pump that comes with the R2.0 EK l120 kit. EK's website states it is a 100 DDC MX 3.1 PWM. problem is I am not sure what pump this is exactly. Is this a DDC 1? a DDC 2?
The reason im asking this, is i had problem this morning getting my pump to start, CPU hit the throttle limit several time till i figured out the pump wasn't spinning. I read one or two reports that a few laing pumps are unreliable on startup as well, mmy pump will take a second or tow to startup after power is applied. I got the pump to start operating again after draining some of the water. Could any of you shed light on this? I would like to know the pump model so that i can purchase a DIYINHK replacement PCB board for if/when this pump dies. DIYINHK.com shows a 60% increase in pump performance with the PCB upgrade too which makes me wonder if i should be upgrading just for that reason alone.
