Hello dear friends,
in the past few months i've been thinking to finally build a PC because i can't take the lag of the notebook anymore.
I already have everything i need including a decent aftermarket cpu cooler. All i need is an opinion on motherboards and whether or not its worth getting the G3258 anniversary Pentium now, or wait and get dual core Skylake.
So.
I want to get the Intel Pentium G3258 and overclock it as high as it can go. I've found an Asus H81m-E for 53 Euros (59 Including Shipping), from what i've read this mobo will support a moderate/decent OC on the said CPU, problem is that its very poor feature wise. It only has 1 fan connector, while my case has 3x140mm fans and i plan on adding more someday. I could buy 4pin to 3pin fan adapters but that's extra cost too.
Or, should i get the Z97 anniversary Asrock motherboard? Better overclocking capabilities, better features (i guess more fan connectors as well?) or generally any other cheap Z97 mobo instead of the H81. I just dont want to spend a lot because this is a budget build and im not going to add a better cpu or a good gpu anyways. I have found the Z97 Asrock Anniversary mobo for 81 Euros including shipping.
Last option, don't get anything and wait for skylake. Problem is, i've heard that the IPC improvement is very small - if any. And i don't think there is going to be a cheap dual core OC'able cpu in the 1151 socket.
Lastly, if you had any experience with any other cheap H81 mobo that could certainly OC the Pentium, please let me know.. it might help me decide.
Waiting for your opinions.. Thanks for reading
So.
