So I ordered a new mcp655 pump and installed it but after one day of it working fine it has stopped pumping completely. Now after taking it off the loop and checking for clogs or any visible problems, it will vibrate every 4 seconds but won't start up properly.
Things I have tried:
-Tip the case in every direction to get the liquid flowing.
-disassembled it
-changed molex spot
-changed the speed controller
When it first happened I was able to tip the case with the mobo facing up and it turned on once I flipped it back upright. After putting it back in its place I again ran into the issue, only this time I could feel it vibrating.
-disassembled it
-changed molex spot
