- Jun 11, 2004
SpeedFan ought to be able to read your GPU temp and control any header that BIOS can control based on that input. Most motherboards have a few headers that can be controlled. It may take some fiddling to get SpeedFan to see the video card temp outputs, but it can usually be done. Check your motherboard specs, though, to make sure you don't overload the header with multiple fans.Hey guys I am just finishing my build and had a question . I have 2 seperate cooling loops one for cpu and one for gpu which is a Evga 980ti hydro copper my question is this video card has no fan header so how do I control my rad fans for my gpu loop. Can my motherboard (Asus rampage revenge) fan header be changed to control gpu heats?
http://almico.com/speedfan.php
You could also get a fan controller with a temp sensor and base the fan speed on the coolant temp. Again watch out for weak units designed to control a single fan.
