Can't tell anything about your flow from that picture, can you get one that's straight-on?
The noise sounds like air in the pump, did you tilt the loop around to get the air bubbles cycled through?
i try move from all sides my case, when i unscrew top screw there was a lot of air. Also if i move case a little bit up for a 1-2 sec pump works ok, but after this back to make noise again.
He means you need to get the air out of your coolant.
If once you've done that the pump is still too noisy, consider suspending it with elastic or mounting it on rubber or foam to keep vibration from being transfered to your case
ok i read many topics and i solve problem with air and bleeding.
I have some results:
When i turn on computer (room temperature is 21deg) pump still make some noise - not so loud like on the movie. But, when i turn off coolers and get much warmer water (above 45) pump are quiet. When coolant gets colder i can hear the noise from pump.
