- Nov 14, 2006
- Warsaw/Poland
As per title. It's easy to find tests from 2007–2010 when 775 was the jazz, but what about modern coolers that simply happen to still support 775?
CPU is a e8600 lapped E0 Wolfie. Rated 65W TDP, typically draws ~100W, up to 200W when it hits 4 GHz on 1.4V, according to testers (I'm new to it, a recent $30 upgrade).
Usually 38 idle on this thing, i.e. Zerotherm CF800, probably not much better than Intel box except for dbAs, cost a grand total of eight bucks. It has a low profile, three pipes, aluminium structure, copper base.
Mobo is ASUS P5Q-E, which means it uses a ton of heatpipes for northbridge, mosfets and everything else around the CPU, and those things usually get mighty hot.
System temperature is often reported at 45C with both case wings removed(!!!11), where CPU and GPU run at 38C each and CPU actually sits right between two large exhaust fans, i.e. top and side exhaust provided by aftermarket 12cm sysfan and 13.5CM OCZ PSU fan.
No intake fans due to case structure — essentially there is no real viable spot for an intake fan on the front, whereas there is a dedicated fan tray in the case wing in 3.5 HDD bay, with holes on the opposing side. Any intake fan I would probably need to mount on the 3.5'' HDD rack (I will, if I have to, I've used fans hanging on cords before...).
Actually, VGA cooler is 12cm intake (upward, i.e. GPU-facing) mounted on Accelero S1 rev. 2 (if memory serves; passive Accelero at any rate, fan simply tied with cords to heatsink fins).
Now, the goal is to not hold back much and just buy a fan that will let me keep Wolfie cool and silent for the time being with some nice OC but will also work great on my next CPU (or 2, or 3) — this essentially means buying a fan that will be great on the newest AMD and Intel CPUs (or just Intel) but still supports 775 and isn't bad for my current CPU area situation in general.
I have no preference either way between tower, orb or anything else, and I'm not a sucker for the looks of thing. Whatever works best in my current situation is gold, while 1) being good for a future CPU in a couple of years (when semi-retiring this PC, I'll just give it back its old cooler); 2) not restricting my future mobo choice too much.
My next case is gonna be the fattest cow I can buy, and my current one is probably gonna have to stay with its wings removed anyway, so height isn't really an issue.
Oh, I almost forgot. P5Q-E transports heat to the back of mobo. And I have no hole in the case there, solid iron underneath. Ugh. Just in case this matters.
Pic (or you wouldn't believe it happened):
Please feel free to make any sort of suggestions*, to your heart's content, for my nickname is very aptly chosen (just in case that hasn't been obvious enough by now).
(* Please note, though, that I'm in Europe. Cross-continental shipment fee from the US would probably nullify any good bargain. Newegg's bargain mill is not an option available to me, unfortunately. Further please note that my IQ isn't catastrophically low, I'm just really clueless with physics, airflows, voltages etc., unlike 90% other posters here.)
EDIT: In the typical scenario VGA cooler is only lukewarm, while the other side of the card is sometimes barely touchable at the same time. (But heat transportation works, as the fins do get hot without a fan, and quickly.)
