- Mar 15, 2014
- Daytona Beach, FL
The fittings I plan to get;
I have no clue yet... I want to go hardline but could use some guidance. Koolance does not use a standard thread, correct? And this could cause some compatibility issues?
The tubing I plan to get;
Koolance fittings use imperial measurements. They are standard to most tubing. But you do not want to mix different brands of fittings, with different brands of tubing. Normally if you are going to use Koolance fittings, you would want to use koolance "Recommended" tubing.
Example: I use 1/2" (13mm) ID x 3/4" (19mm) OD tubing for soft tubing. So if I were to use koolance, I would use this tubing.
http://www.performance-pcs.com/kool...c-1ft-30-5cm-id-13mm-1-2in-od-19mm-3-4in.html
And for the fittings, I would use these compression fittings
http://www.performance-pcs.com/fitting-single-compression-for-13mm-x-19mm-1-2in-x-3-4in-black.html
This is just an example, you do not have to go these parts, but its a good representation of what you should do when it comes to fittings/tubing. And when it comes to Hard-Line. You want to go a smaller ID x OD like 3/8" (10mm) ID x 1/2" (13mm) OD. It is cleaner looking, and very good for tight bends. For example, if you have a Radiator on top, in the back (Using the 120mm OR 140mm Exhaust Fan), and then one in the front. If you are not using a Case Labs case, or the Corsair 900D, You will need the smaller OD tubing to get it into those super tight bends from the exhaust radiator to the NB, or from the VRM to the Radiator, or vice versa. I hope this helps you understand what you need to get. I personally would get 2 pumps, once you go past 3 blocks, and more than 2 radiators. Not really for head pressure, more for redundancy. If one fails, your whole system won't go with it.
This is my first Hard-Line build, I just started it a couple days ago, i had 5 x 500mm tubing and used them all, and still need 1 more connection. I messed up a lot by re-heating, and trying to re-bend a tube I already bent. IT WILL NOT WORK. It folds onto itself and rips.
