Vrm heatsinks are usually a good idea on any board, when it comest to these Fx 8xxx chips it's more then just that. I'm hoping that you putting VRM heatsinks on the board and possibly actively cooling it will help with the issue. Though, with these chips even at stock clock speeds a midrange board with at least a 6+2 Vrm section is the minimum I would try and run one on. If you do decide to look for a new motherboard down the road for the 8350 please ask us for help first. That way you can get a board that will work well with the chip.Think you guys are right, its heat related.
With putting my pc on heavy load, I hand touched the VRMs, and they are hot as hell, almost to hot to touch by fingers, its bearable but still way to hot then what it should be.
Thanks for pointing me in the right direction at least, now I at least know what to do.
Now I know on my next build to look for heat sinks on vrms as well.
The M5A99FX Pro is a good board, for a mild Oc. You'll probably top out at around 4.5 Ghz is you tried Ocing on that board, I have a similar M5A99x Evo.can a board make a computer run faster at all? thats why i went cheap on my mobo and guess i ended up paying for it.. Gpu and cpu were more important to me.
What do you think about Asus M5A99FX PRO R2.0 ???
probably about 200 max is my budget, but i would like to stay within 1-150.
You'll most likely need to reinstall no matter what since you'll be moving from a 970 chipset to a 990 chipset.
Maybe. I just went from a sabertooth 990fx to a Asrock 226 WS. Amd to intel, and an odd chipset at that. No re-install required, just some drivers.
Your mileage may vary.
EDIT: Windows 7.
