Hello Guys
I am in the final stages of building my x99 build and I am having issues with choosing a water-cooling setup. My original plan was to buy the EK-KIT X360 (from EK), but seeing how I really want to have either a 420mm or a 480mm radiator, I am thinking of not buying the kit and instead buying most of the components that come with the kit and just buying separately the radiator and the fans that I really want. (I hope that makes sense)
That being said, I need some help with the radiator and fans. Mainly, which one is better for quietness and performance given my case and the PC build (see below)… a 420mm or a 480mm? Are there any fans that are better for quietness and performance compared to others?
Another question that I have is that I plan to buy the EK-DDC 3.2 PWM Elite Edition, Water Pump (the one that comes with the kit) and I wanted to know if it be able to handle the larger radiator (and a 2nd radiator if I install one) without problems?
Lastly, which parts would I need to be able to fill and drain the system without problems? (This is also something that the kit doesn’t come with )
Any and all help is greatly appreciated!!
Here is my x99 Build: (I plan to overclock it)
PHANTEKS Enthoo Primo
MSI X99A SLI Plus
Intel Core i7 5820K
Corsair Vengeance LPX schwarz DIMM Kit 16GB, DDR4-2666
Gigabyte GTX 980 Ti G1 Gaming 6 GB (possible SLI in the future)
Samsung SSD SM951 256GB, M.2 - PCIe
Samsung SSD 850 Evo 500GB, SATA (possible Raid setup in the future)
EVGA SuperNOVA 1000 P2 Power Supply
MSI X99A SLI Plus
Intel Core i7 5820K
