jamesbp2015
- Nov 29, 2015
Hello,
I’m having a problem I hope someone can help with. I have the following system which I just recently added the second video card for SLI and two additional matching LCD screens:
- Intel i5-3570K CPU 3.5GHz (overclocked to 4.1GHz)
- 16GB DDR3 Memory
- SATA3 480GB SSD Drive
- 2 Asus GeForce GTX690 graphics cards (2 GPUs each - Quad SLI).
- 3 Samsung 1920x1200 60Hz Displays
- NVIDIA Surround 5970x1200 (bezel corrected) Resolution
- Windows 7 (64bit)
My problem is that in most games I’m getting horrible stuttering, even though my framerate is at 55-60FPS (vertical synced). The stuttering if fairly constant in some games, somewhat sporadic in others. I don’t think this is any kind of SLI micro-stutter because on a single screen at 1920x1200 it’s perfectly smooth with Quad SLI. (I always have the NVidia SLI Visual Indicator turned on so I know SLI is working and seems to be scaling well)
Does anyone have any idea what the problem might be or how to figure out what’s causing the issue?
Thank you,
-James
- 16GB DDR3 Memory
- Windows 7 (64bit)
Thank you,
-James
