Ok great, thanks I will try that.
So I've tried every possible combination I can think of and the best results I got so far is the switch light on when the clipper is off and the light turns off when the clipper is turned on. Is it possible that's just the way the switch is - lights in reverse?
These are the combinations ive tried and their and results:
Red to pin 1, black to pin 2 - powers clipper/ no lights
Pin 1 jumped to pin 3 (gold) light works when clipper is off/ turns off when clipper is on
Pin 1 jumped to pin 2 turns clipper power on/no lights
Pin 2 jumped to pin 3 (gold) n/a
Red to 1 black to 3 - light works properly (off when off/on when on) / no power to clipper
Pin 1 to pin 2 light is on constant in on AND off position/ no clipper power
Pin 2 to pin 3 powers clipper/ light is on in off position, turns off when switched on
Pin 1 to pin 3 n/a
Red to 2, black to 3 - light is on constantly, no power to clipper
Pin 1 to pin 3 powers the clipper but turns the light off
Pin 2 to pin 3 power is on constant
Pin 1to pin 2 n/a
Red to 2 black to 1 - powers clipper/ no lights
Pin 1 to 3 light on when clipper is off, turns on when on
Pin 2 to 3 n/a
I've also tried this with multiple switches from different manufacturers so I am completely stumped at this point
