Yea, the board is the problem and it is bad. How do I know? It just died.
What happened? One of the first issues I was experiencing was rapid back to back Win10 notifications "surge on USB port - a USB device requires more power than what is available" and the popups wouldn't stop. I have three USB devices which are my keyboard, mouse, and Logitech G13 gamepad which all plug into the ports on the motherboard.
I looked at the cables and they were all plugged in securely, but I lost control of my mouse so I had to do a shutdown through task manager on the keyboard. Once it was off I unplugged the devices and then hooked them back up so this corrected that problem since I didn't get any more of those notifications when I got back into windows.
Then running cpu-z I noticed my PCI-e 3.0 x16 link width was now at x8. I reseated the graphics card twice and when I would boot back into windows it would start off in x16, but to test it out I would game for about 15 minutes and exit to check cpu-z again. Back down to x8. I tried to reseat it a third time, but this didn't do anything and from that point on it was permanently stuck in x8.
Not long after that, about 30 minutes later, the PC completely froze. I couldn't move the mouse cursor and CTRL+ALT+DEL wouldn't bring up task manager so I had to do a hard shutdown pressing and holding the power button. It hasn't booted up since.
I press the power button, the LEDs come on, the cpu and case fans power up, but I can't get a BIOS screen and it won't pass POST. So Gigabyte techs reported within one day of having the board that they didn't find any issue with it, but they held onto it for over two weeks.
They returned to me the same faulty board which is in the same bad state it was initially in when I sent it off for repairs. Scott was right all along - the board was the original culprit for the first problem and in less than one day of having it back from RMA it has now completely died.
I just sent another RMA request to Gigabyte tonight and I may have been a little harsh, but I told them I want a replacement or a refund directly from Gigabyte and repair is not an option this time so they didn't attempt to fix it the last time they had it.
I also told them when I send them back their broken board I refuse to pay for shipping this time since they didn't do anything at all to the board. They just tested it, held onto it for an unusually long time and then returned it to me faulty. This proves though they didn't test it thoroughly or for very long.
So wingman, what did you mean by a bad board with an 8x problem? Which 8x problem are you specifically referring to?
I always knew the lane would run at PCI-e 2.0 and, yes, the lane will knock down to save power when in idle, but both cpu-z and gpu-z would report that the PCI-e 3.0 x16 lane was @ 2.0 x8. A few times I would start up the computer and the lane would be 2.0 x16 on bootup, but after gaming for a few minutes it would revert back to x8. At one point in time both programs reported 2.0 x1 link width - this was shortly before the board died.Mine only runs at pcie 2.0...also, try measuring with gpuz, and running the rendering test.
I spent good money on this board and what Gigabyte did is unacceptable. They will make this right one way or the other, I'm going to make sure of it.Neither of the CP member's boards came back working 100% either.
On a side note: everyone seems to be bashing the Gigabyte boards for the last few weeks. I have had 0 issues with mine, so there are 2 possibilities:
1- I got real lucky and got a good mobo out of a bad design. Seems unlikely to me....
2- there are other issues with people's setups. In this case people are leaning towards power supply.
Don't get me wrong, Gigabyte has had some design issues. The R5 series is solid in my book thus far. It appears to me that Gigabyte has resolved the design issues completely with this release.
This is only the third time I have bought a Gigabyte product and the last ones I owned, another motherboard and gpu, both crapped out in under a year. However, back then I could get the appropriate service I needed to have my products fixed or replaced with little to no hassle since Gigabyte went out of their way to take care of their customers.My comment on the bashing was that most people seem to be dismissing products from gigabyte as terrible, when it is far from the truth.
It's fine homie, I didn't take it that way. I was simply elaborating the issue a little further for better clarification. You and I are at odds ends though in your defense of Gigabyte though which I think to be undeserving.My apologies if it seemed I was attacking you and your situation. That was not my intent.
I'm not bashing anything.
It is a UD3. It is Gigabytes entry level line. It is what it is. There are still design issues and always will be because it is an entry level, dead socket board. They will never be addressed.
Of your two scenario's you posted, consider yourself lucky. Your hardware or skills are no better or worse than anybody else's, and I'm being kind with that because the two CP guys are way ahead of you on both counts.
I'm not butthurt, I was merely agreeing with you Mr. Scott. I am not knowledgeable on this at all and should stop posting. I voiced my uninformed opinion, and now I am done. Now of you don't mind, I'll go enjoy my golden egg of a Gigabyte board(because it functions) and play a few more rounds of overwatch...You're taking it way out of context man. It wasn't meant for you to get butt hurt over.
Along with the CPU and the liquid cooler. The mobo was RMA'd, but GB screwed me.The OP has basically replaced everything except the mobo. The PSU was RMA'd.
Gee, rub it in my face you have a working GB board why don't youI'll go enjoy my golden egg of a Gigabyte board(because it functions) and play a few more rounds of overwatch...
I'm kidding dude. I'm just being cynical.
I agree. The only 970 board that I'd consider is the 970 Pro Gaming Aura.
