Well I hate to be "that guy" but I don't really see a scenario where this would be beneficial. You guys need to remember, heatpipes may be a good way to get heat from point A to point B, but in this scenario it is an extra step. We've discovered long ago in the WC world that you get the best performance out of relatively thin WC block bases. Big fins, pins, thick bases, "cold plates" (copper slabs / shims / heat spreaders) have all been tested and don't offer any benefit.
The goal here is to get the CPU heat from the CPU, into the water. As fast as possible. And the most efficient way to do that is through a couple MM of copper. In this case, you still need to go through a few millimeters of metal, but there's more going on too. It'd be kind of like thinking that if you were to drive a generator with an electric motor, you'd end up with more electricity in the end than what you started with. You can't get anything for free, and that includes heat loss. We already have very efficent WB designs.
The acrylic work is impressive though! And I'm still interested in results on how this works. I don't think it'll be ground breaking though, my guess is weaker performance than any WB on the market. I hate to be rude, but that is simply where my best judgement points me. I definitely appreciate the ideas and craftsmanship that went into this thing. I'd like to see those efforts applied into the construction of a custom built AIR cooler, where there may be some room for improvement.
