Mmmm... The xbox one can deliver a good 8 fps@4K (30/4),
*douche voice* Uuuum to be exact its 7.5.. But i will give that one to you.
Ah, bah, you know, rounding!
Well aware he has a 1070...never said it was close to good enough. My post mentioning a single 1080 was off yours saying 2 1070s or 2 1080s were needed. Oy.Just joking bud!
Sure the 1080 is a strong card (very strong ), but a little 1070 is not as strong, and the OP will have to do some sacrifice on IQ to run 60 fps/4k.
TBH, 1 1080 would suit me for 4k. If you have a spare one, I will unload your burden for free with pleasure !
Why no one actually focused on the main questions? this is in Cooling section, and if you telling me "couple" 1080s MIGHT be enough for 4k then u better go buy a xbox 360.
if my loop be Pump>360mm radiator>oc cpu>oc gpu>back to pump is ok? or i better add another 240 radiator. i kno its always good to have more but i rather go with single 360mm if thats enough
We are all helping you.
I have so far. That's how I ended up with the rig in my sig this month. It's turning in to an addiction, though!
Seems like yall making it fun in here lol
I am not too worry about 4k in 60fps. im fine with mid 40s fps. that's y im saving almost 300 bucks by not going with 1080 ( even tho watch me do it at the last minutes lol )
A good quality (like fat alphacool) 360mm radiator is enough to cool off both overclocked GPU and CPU? Is it safe to direct the loop from CPU directly to GPU ( its not going to be hot enough)?
i kno its better to have 2 radiators but i prefer not to spend extra except if i have to.
I didn't answer that already in post #3?
http://www.overclockers.com/forums/...for-my-build?p=7950290&viewfull=1#post7950290
A properly flowing and radded loop, the loop order does not matter. Temps vary very little from point to point. You just want to make sure the res is before the pump. It will be enough, but if it was me, I would do two rads for better results.
Don't get a 1070 for 4K...really. A 1080 can get by. A 1070 you will have to turn settings down, etc. If you are going to go 4K, get a proper card for it is my suggestion. I would even forego water to get the better card honestly.
I would go with a thinner 360 and 240 rad vs buying one thick 360. Yes the thick 360 can handle the load and Yes two rads are more expensive than 1 (but not by much). The benefit is you will have a quieter system that will allow for additional load down the line.
For example a Alphacool ut60 360 rad is about $140. A alphacool xt45 360rad and 240 rad would cost about $175 combined. That is an extra $35 I would spend.
As ED said, as long as you maintain a proper flow rate it will not make a noticeable difference. Yes you will see an improvement by going res-pump-cpu-240-gpu-360-res but we are talking maybe 1 or 2 degrees. I would worry more about efficient tubing layouts that optimize the case instead of focusing on loop order. Just make sure the res feeds the pump.
