- Aug 11, 2002
- St. Louis, Mo. U.S.A.
I call that mounted vertically...a possible assumption on my part
is your concern about it interfering with your memory slots if mounted horizontally? if so look at this thread and scroll down. I know your mobo is different than mine...but still could be helpful
http://www.overclockers.com/forums/...ith-motherboard-choice-for-new-build-(gaming)
What is the make and model of the case you're using?
I've been searching for this all over the case but I haven't found the model yet? Where do I check?
