- Dec 31, 2016
The First Double Sided Mod Art QUADRAD Custom Case In The World / With Four Loop Four Rad Four Rez
Hello there. Welcome to my new project.[IMG]
We designed a big extreme case. A case with a square look.
4 radiators, 4 pumps, 4 reservoirs in the system. I wanted to build a system with 4 loops.[IMG]
For this reason the name QUAD-RAD.
Case design is mine.
This case can be used in different systems.
The case would be made from scratch, not by modifying a standard case.
After our first work, we decided to make a case in this view.
Case Designed as square cross-section and 45 degree broken.
The case is a plain-flap shape with the front and rear top panels on the wings.
It is designed to bend 45 degrees towards the side covers.
With this, the depth of the cradle, normally 18 cm, was removed by 30 cm.
